Don’t miss AIMMS Connect Day Netherlands on June 24. Learn from our customers, discover new ideas, and connect with the community. Secure your spot now.
Why Temporary Capacity Solutions Matters
Large enterprises are balancing growth ambitions, service commitments, capital discipline, and operational stability across multi-site manufacturing and distribution networks. Capacity decisions no longer belong to one plant or one function; they shape the performance of the whole network.
Why Temporary Capacity Solutions Is Challenging
Temporary capacity is one of the easiest levers to approve and one of the easiest to misuse. When demand surges or supply tightens, leaders often reach for overtime, external manufacturing, or temporary labor because those options feel fast. The harder question is whether they are actually the right answer.
This use case is about deciding when temporary capacity should be used, where, and in what mix. The goal is not simply to cover a shortfall, but to do so in a way that protects margin, service, and operational stability while avoiding permanent responses to temporary problems.
The Cost of Poor Decisions in Temporary Capacity Solutions
Using the wrong temporary capacity mix can erode margins, destabilize operations, and create recurring dependence on expensive short-term fixes. It can also hide structural capacity issues that would have been better solved through a more deliberate medium- or long-term response.
Why Traditional Temporary Capacity Solutions Approaches Fall Short
Temporary capacity solutions are difficult because they sit at the intersection of urgency and economics. Overtime may preserve service but degrade labor efficiency and increase error rates. Subcontracting may add volume quickly but introduce quality risk, lead-time complexity, or hidden transport costs.
Temporary labor may ease a local constraint but fail to address an upstream bottleneck. The decision is also hard because temporary measures can create strategic distortion. What begins as a short-term bridge can quietly become a standing operating model if the business lacks visibility into the real trade-offs.
What Better Temporary Capacity Solutions Decisions Require
What buyers now need is a network-level view of constrained resources, realistic capacity assumptions, scenario speed, and explicit trade-offs between capital, service, utilization, resilience, and CO2.
A Practical Approach to Temporary Capacity Solutions
  • Clarify the nature and duration of the shortfall. Separate true short-term peaks from recurring structural shortages. Temporary solutions should solve temporary problems, not mask permanent ones.
  • Define the feasible temporary levers. List realistic options such as overtime, third-party production, temporary labor, extra shifts, or selective service prioritization. Each option should include cost, speed, quality, and operational limits.
  • Compare scenarios in network context. Evaluate how each lever affects cost-to-serve, service reliability, plant stability, inventory exposure, and downstream logistics. The cheapest local option is not always the best business outcome.
  • Choose the bridge and set the exit conditions. A strong plan defines not only which temporary actions to use, but also when they should stop and what longer-term response, if any, should replace them.
What Strong Temporary Capacity Solutions Looks Like
What good looks like is a temporary capacity plan that is explicit, time-bound, and economically transparent. It supports service during a shortfall without quietly becoming an uncontrolled cost layer or a substitute for structural planning.
Common Temporary Capacity Solutions Pitfalls to Avoid
  • Using temporary capacity by default. Fast does not always mean correct.
  • Comparing options on rate only. The true cost includes quality, transport, and operational side effects.
  • Failing to define an off-ramp. A temporary measure without an end condition often becomes permanent by inertia.
How AIMMS Supports Temporary Capacity Solutions
SC Navigator allows teams to compare temporary capacity options within the broader network, capturing the impact on costs, flows, service, and constraints across plants and markets.
For businesses with very specific decision rules around subcontracting, shift design, or cost structures, the AIMMS Optimization Platform can support a more tailored application layer.
AIMMS stands out by combining packaged speed, optimization depth, and a path from standard use cases to more specialized enterprise decision applications.
Why a Better Temporary Capacity Solutions Approach Works
A strong decision process does not just produce an answer; it makes the answer explainable. Teams can compare scenarios side by side, pressure-test assumptions, and align more quickly because the trade-offs are visible rather than hidden in disconnected files.
The Outcome of Better Temporary Capacity Solutions Decisions
Done well, temporary capacity solutions shifts the organization from reactive debate to repeatable decision intelligence: faster decisions, fewer avoidable compromises, and a supply chain that is easier to improve over time.
“The goal is not just to answer should we use overtime, subcontracting, or temporary capacity to meet demand; it is to make that answer faster, clearer, and easier to trust.”
Speak with AIMMS to explore how this use case can be modeled in SC Navigator and, extended with add-on modules or the broader AIMMS Optimization Platform.
