Don’t miss AIMMS Connect Day Netherlands on June 24. Learn from our customers, discover new ideas, and connect with the community. Secure your spot now.
Why Rough Cut Capacity Planning Matters
Large enterprises are balancing growth, service levels, and cost. But too often, plans are created without a clear view of whether the network has the capacity to deliver. Rough cut capacity planning provides an early, high-level check to ensure demand and capacity are aligned before detailed plans are locked in.
Why Rough Cut Capacity Planning Is Challenging
Most mid-term capacity problems do not fail because nobody saw them coming. They fail because organizations notice them too late, or are looking too locally. By the time a plant manager raises a concern, commercial commitments have already been made and the most cost-effective options are no longer viable. Rough cut capacity planning provides the bridge between long-range strategy and short-term scheduling. Over a horizon of roughly three to eighteen months, it shows whether forecast demand can be supported by available production capacity, where bottlenecks are likely to appear, and which allocation moves best balance cost, service, and operational stability.
The Cost of Poor Decisions in Rough Cut Capacity Planning
Weak rough cut capacity planning leads to service level shortfalls, excess cost, and constant replanning. Plants become overloaded while parallel sites remain underused. Teams fall back on expedites instead of making deliberate trade-offs. Customer commitments become unreliable as plans keep changing. Why Traditional Rough Cut Capacity Planning Approaches Fall Short
This decision sits between strategic planning and detailed scheduling—too complex for high-level assumptions, but too early for detailed sequencing. Product mix, campaign lengths, shared resources, and maintenance windows all play a role. Yet many organizations still try to manage this level of complexity with broad utilization assumptions and disconnected spreadsheets. The difficulty only compounds in multi-plant networks. A shortage in one site alters sourcing choices, transport flows, inventory exposure, and sometimes the service profile for multiple markets. What looks like a local overload is often a network-level trade-off in disguise.
What Better Rough Cut Capacity Planning Decisions Require
What buyers now need is a network-level view of constrained resources, realistic capacity assumptions, scenario speed, and explicit trade-offs between capital, service, utilization, resilience, and CO2 emissions.
A Practical Approach to Rough Cut Capacity Planning
  • Translate forecast demand into resource load. Convert demand into the operational language that actually consumes capacity: line hours, machine hours, labor hours, campaign time, or changeover load. Rough cut planning becomes actionable only when demand is expressed in the same terms as the constraint.
  • Use accurate available capacity.  Account for maintenance, labor availability, efficiency loss, committed production, and guardrails that keep operations stable.
  • Evaluate allocation scenarios across the network. Test plant-to-plant shifts, alternate sourcing rules, product-family ownership changes, selective overtime, or temporary subcontracting. The value of each option depends on its network consequences, not on the plant view alone.
  • Select the most effective plan and define triggers. Choose the plan that performs well across plausible changes in volume and mix, and define the triggers that tell the organization when to activate contingency moves.
What Strong Rough Cut Capacity Planning Looks Like
Good rough cut capacity planning gives a time-phased view of demand load, constrained resources, and recommended allocation actions by site. It distinguishes between structural shortages and temporary peaks, and it turns a recurring monthly argument into a repeatable decision process.
Common Rough Cut Capacity Planning Pitfalls to Avoid
  • Using average utilization assumptions. Capacity problems are usually caused by specific resources, mix effects, or timing peaks, not annual averages.
  • Treating plants as independent islands. Local optimization often creates global inefficiency.
  • Waiting for detailed scheduling to reveal structural issues. By then, the remaining options are usually expensive.
How AIMMS Supports Rough Cut Capacity Planning
SC Navigator enables planners to model facilities, constrained resources, demand regions, and operational trade-offs within one network view. That makes it possible to compare capacity-allocation scenarios on cost, service, and utilization outcomes far more consistently than manual spreadsheet models. The AIMMS Optimization Platform can extend this for organizations with highly specific production rules or custom allocation logic. AIMMS stands out by combining packaged speed, optimization depth, and a path from standard use cases to more specialized enterprise decision applications.
Why a Better Rough Cut Capacity Planning Approach Works
A strong decision process does not just produce an answer; it makes the answer explainable. Teams can compare scenarios side by side, pressure-test assumptions, and align more quickly because the trade-offs are visible rather than hidden in disconnected files.
The Outcome of Better Rough Cut Capacity Planning Decisions
Done well, rough cut capacity planning shifts the organization from reactive debate to repeatable decision intelligence: faster decisions, fewer avoidable compromises, and a supply chain that is easier to improve over time.
“The goal is not just to answer how should we allocate production capacity to meet forecast demand in the mid-term; it is to make that answer faster, clearer, and easier to trust.”
See how AIMMS helps you balance mid-term demand and capacity with more confidence.
