Don’t miss AIMMS Connect Day Netherlands on June 24. Learn from our customers, discover new ideas, and connect with the community. Secure your spot now.
Why Nearshoring Vs Offshoring Matters
For most of the past three decades, the dominant logic of global supply chain design was offshoring: move production to where labor and input costs are lowest, accept longer supply chains, and manage the resulting lead times and inventory requirements as a cost of doing business. That logic is under pressure. Geopolitical volatility, tariff exposure, pandemic-driven disruption, and growing pressure to reduce carbon emissions have all made the cost of long, concentrated supply chains more visible and more variable than they appeared when offshoring decisions were made. Nearshoring, bringing production or sourcing closer to the markets being served, has moved from a niche option to a mainstream strategic consideration. The question is no longer whether to consider it but how to evaluate it rigorously before committing to a structural change that is expensive to reverse.
Why the Nearshoring Vs Offshoring Decision Is Challenging
The challenge is that nearshoring and offshoring trade-offs cannot be evaluated on cost alone. An offshore production model that minimizes unit cost may carry duty exposure, lead time risk, resilience vulnerability, and carbon cost that are not visible in a unit cost comparison. A nearshore model that appears more expensive on a unit cost basis may produce lower total landed cost once duties, inventory, and risk mitigation are included. The right answer depends on modeling the full economics of each sourcing configuration across a range of demand, cost, and risk scenarios.
The decision is also strategically significant in ways that make it politically difficult. Moving production or sourcing affects supplier relationships, workforce commitments, customer lead time promises, and carbon reporting. These consequences extend well beyond the supply chain and require alignment across commercial, finance, operations, and sustainability functions. That alignment is difficult to achieve without analysis that is transparent enough for all stakeholders to interrogate and specific enough to connect the sourcing decision to the outcomes each function cares about.
The Cost of Getting This Decision Wrong
An offshoring decision that underestimates total landed cost or overestimates supply chain resilience produces years of higher-than-expected cost and more frequent service disruption than the business case assumed. A nearshoring decision that overestimates the cost reduction or underestimates the transition complexity produces capital commitments and operational disruption that erode the margin improvement the move was meant to deliver. Either way the consequences are structural and persist for as long as the sourcing model remains in place.
Why Traditional Approaches Fall Short
Nearshoring and offshoring decisions are typically evaluated through a combination of unit cost comparison, landed cost estimation, and qualitative risk assessment. Unit cost comparison captures the production economics but misses the logistics, duty, inventory, and risk costs that often determine the total outcome. Qualitative risk assessment acknowledges the resilience dimension but cannot quantify it in a way that allows it to be weighed consistently against cost. Without a network model that holds all of these dimensions simultaneously, the decision is made on an incomplete picture of the economics.
What Effective Nearshoring vs Offshoring Analysis Requires
Supply chain leaders need a model that can evaluate alternative sourcing configurations against total landed cost including production, duties, transport, inventory, and risk mitigation simultaneously, test those configurations against a range of demand and disruption scenarios, and connect the sourcing decision to its consequences for service, resilience, carbon, and margin across the full network.
A Practical Approach to Nearshoring vs Offshoring Analysis
  1. Define the full cost structure of the current sourcing model. Start by calculating the true total landed cost of the existing configuration: production cost, duties and tariffs, primary and secondary transport, inventory holding driven by lead time, risk mitigation cost, and any premium logistics cost incurred when the supply chain is disrupted. This baseline reveals the real economics of the current model rather than the unit cost that typically anchors the comparison.
  2. Model alternative sourcing configurations against the same cost structure. For each nearshoring or regional sourcing option under consideration, calculate the same full cost components and compare them against the current model baseline. Pay particular attention to the duty and inventory implications of each option, as these are the cost components most likely to shift the comparison materially in either direction.
  3. Test each configuration against disruption and volatility scenarios. Evaluate how each sourcing model performs when conditions change: a significant tariff increase on the current sourcing geography, a supply disruption at the primary production site, a demand surge in a specific market, or a tightening of carbon reporting requirements. A nearshoring decision that looks marginal on current economics may look compelling once the cost of managing a disruption in the offshore model is included.
  4. Evaluate the transition path and its cost. A sourcing shift of this scale involves supplier qualification, production ramp-up, inventory build during the transition, and potential service disruption while the new model is being established. Model the transition cost and timeline explicitly so the investment required to shift the sourcing model is visible alongside the steady-state benefit of doing so.
What Strong Nearshoring Vs Offshoring Looks Like
A rigorous nearshoring versus offshoring analysis produces a clear view of the total economics of each option across a range of scenarios, with the trade-offs between cost, service, resilience, and carbon made explicit. The decision is grounded in the full landed cost of each configuration rather than in unit cost comparison, and the transition cost is included so that the timeline to value realization is understood alongside the steady-state benefit.
Common Pitfalls to Avoid
  • Comparing sourcing options on unit cost alone. Duties, transport, inventory, and risk mitigation frequently reverse the economics of a unit cost comparison when included in full.
  • Evaluating the steady-state economics without modeling the transition. The cost and disruption of moving to a new sourcing model is a real part of the investment decision.
  • Making the decision without scenario analysis. The economics of nearshoring versus offshoring depend significantly on tariff environments, disruption frequency, and carbon costs that are all subject to change.
How AIMMS Supports Nearshoring Vs Offshoring Analysis
AIMMS allows teams to model alternative sourcing configurations within the full network, evaluating total landed cost including production, duties, transport, inventory, and risk mitigation simultaneously rather than in separate analytical workstreams. Tariff structures can be incorporated directly into the model so that the duty implications of alternative sourcing geographies are reflected in the economics rather than estimated separately.
Disruption and volatility scenarios can be run quickly against each configuration, making the resilience dimension of the decision quantifiable rather than qualitative. For organizations dealing with complex multi-region sourcing decisions, specific duty structures, or carbon reporting requirements, AIMMS supports fully tailored solutions on the same optimization foundation.
The Outcome
Organizations that evaluate nearshoring and offshoring decisions with full network modeling make sourcing choices that reflect the true total economics of each option rather than the unit cost comparison that typically anchors the debate. The result is fewer sourcing decisions that look right on paper but deliver disappointing outcomes in practice, and a clearer understanding of the conditions under which nearshoring generates genuine value versus those where offshoring remains the better answer.
“The unit cost of offshore production is visible. The total cost of an offshore supply chain, including duties, inventory, resilience risk, and carbon, is what actually determines whether the decision was right. ”
See how nearshoring versus offshoring analysis helps you compare total landed cost, resilience, carbon, and transition trade-offs more effectively.
