Why Last-Mile Delivery Network Design Matters
Last-mile delivery is the most expensive, most carbon-intensive, and most service-critical segment of most distribution networks. The cost of moving a unit from a distribution center to an end customer typically exceeds the cost of moving it from a production facility to the distribution center, often by a significant margin. That cost is driven by the structural characteristics of last-mile delivery: low density, frequent stops, short delivery windows, high customer service expectations, and the combinatorial complexity of routing vehicles efficiently across a dispersed delivery geography. Getting the last-mile network structure right, including where fulfillment points are located, how delivery zones are defined, which modes and carriers serve each zone, and how vehicle routing is organized, determines whether the last-mile operation is a manageable cost or a structural drag on margin.
Why Last-Mile Delivery Network Design Is Challenging
The difficulty is that last-mile delivery involves a set of structural decisions that interact in ways that are not visible from an operational perspective. The location of fulfillment points determines the distance vehicles must travel to reach customers, which determines vehicle utilization and cost per delivery. The definition of delivery zones determines the density of stops within each zone, which determines how efficiently routes can be built. The choice of delivery mode, whether own fleet, third-party carriers, crowdsourced delivery, or alternative access points such as lockers and collection points, determines the cost structure, the carbon profile, and the service level the last-mile operation can deliver.
These decisions interact with customer expectations that are increasingly demanding and increasingly varied. Some customers require same-day or next-day delivery. Others accept longer windows in exchange for lower cost. Some want home delivery; others prefer collection points. A last-mile network designed for one customer profile performs poorly when the customer mix shifts, which means the network structure needs to be evaluated against the full range of service requirements rather than a single average assumption.
The Cost of a Poorly Designed Last-Mile Network
Last-mile inefficiency is expensive in ways that compound at scale. Fulfillment points that are too far from customer concentrations drive up vehicle distance and cost per delivery. Delivery zones that are too large reduce stop density and increase route length without proportionate volume increase. Routing that does not account for time windows, vehicle capacity, and stop sequencing simultaneously leaves vehicle utilization and cost efficiency on the table. And a delivery model that does not differentiate between customer service tiers, serving every customer at the same cost regardless of the value of the relationship, consistently over-invests in low-value delivery while under-pricing the premium service that high-value customers would pay for.
Why Traditional Approaches Fall Short
Last-mile network design in most organizations is driven by operational growth rather than analytical design. Fulfillment points are added as demand grows in new areas, delivery zones are defined by geographic convenience rather than density optimization, and routing is managed by transport management systems that optimize individual routes without considering the full structural design of the delivery network. The result is a last-mile network that reflects how the operation grew rather than how it should be designed, with fulfillment point locations, zone definitions, and routing structures that have never been evaluated together as a system.
What Effective Last-Mile Network Design Requires
Supply chain leaders need a model that can evaluate alternative last-mile network structures including fulfillment point locations, delivery zone definitions, mode and carrier choices, and routing approaches simultaneously, optimize against delivery cost, service performance, and carbon emissions across the full customer base, and identify the structural configuration that serves customer requirements most efficiently at the lowest total cost.
A Practical Approach to Last-Mile Delivery Strategies
  1. Map the current last-mile cost and service profile by zone and customer segment. Document current fulfillment point locations, delivery zone boundaries, stop density by zone, vehicle utilization, delivery cost per stop, service window compliance, and carbon emissions per delivery. This baseline reveals where the current network structure is performing efficiently and where structural inefficiency is most concentrated.
  2. Evaluate alternative fulfillment point configurations. Model the effect of adding, removing, or relocating fulfillment points on delivery distance, stop density, vehicle utilization, and total delivery cost across the full customer base. Fulfillment point location is the most significant structural lever in last-mile network design because it determines the distance envelope within which all downstream routing decisions operate.
  3. Define delivery zones and service tiers that reflect customer density and service requirements. Design delivery zones that maximize stop density within each zone, and define service tiers that match delivery cost to customer value. High-density zones with high-value customers justify premium service models. Low-density zones with cost-sensitive customers may be better served by consolidated delivery models, alternative access points, or third-party carriers who can aggregate volume across multiple shippers.
  4. Optimize routing within the structural network design. Once fulfillment point locations and zone structures are defined, optimize vehicle routing within each zone simultaneously across the full fleet, accounting for time windows, vehicle capacity, driver availability, and stop sequencing constraints. Routing optimization within a well-designed zone structure consistently achieves better vehicle utilization and lower cost per delivery than routing optimization applied to a poorly designed zone structure.
What Strong Last-Mile Network Design Looks Like
A well-designed last-mile network has fulfillment points located to maximize stop density within delivery zones, zone structures that match delivery economics to customer density, service tiers that align delivery cost with customer value, and routing that maximizes vehicle utilization within each zone. The cost per delivery is minimized at the structural level before routing optimization is applied, which means routing tools are working on a well-designed problem rather than compensating for a poorly designed network.
Common Pitfalls to Avoid
  • Applying routing optimization to a poorly designed network structure. Route optimization can only find the best routes within the structure the network provides; structural inefficiency in fulfillment point locations and zone definitions limits what routing optimization can achieve.
  • Designing the last-mile network for average customer requirements. The customer mix is not uniform and the network structure needs to reflect the full range of service requirements rather than a single average assumption.
  • Treating the last-mile network as fixed between major operational reviews. Customer density patterns, service expectations, and carrier markets all change continuously and the network structure needs to be revisited when those inputs shift materially.
How AIMMS Supports Last-Mile Network Design
AIMMS allows teams to evaluate alternative last-mile network structures including fulfillment point locations, delivery zone configurations, and mode and carrier choices simultaneously, optimizing against delivery cost, service performance, and carbon emissions across the full customer base. At the structural level the optimization tooling identifies the fulfillment point configuration and zone structure that minimizes total last-mile cost while meeting service requirements. At the operational level AIMMS applies advanced optimization to vehicle routing within the defined zone structure, accounting for time windows, vehicle capacity, and stop sequencing constraints simultaneously across the full fleet. For organizations with complex urban delivery networks, specific service tier requirements, or last-mile design challenges that span multiple fulfillment points and customer segments, AIMMS supports fully tailored solutions on the same optimization foundation.
“Route optimization finds the best routes within the network you have. Last-mile network design determines whether the network you have is the right one to optimize in the first place.”
The Outcome
Organizations that design their last-mile network structure analytically operate with lower delivery cost per stop, better vehicle utilization, more consistent service performance, and lower carbon emissions per delivery than those that manage last-mile through operational growth and route-level optimization alone. The structural improvement compounds across every delivery cycle, making last-mile network design one of the highest-return analytical investments available in distribution management.
Speak with AIMMS to explore how last-mile delivery networks can be designed and optimized, from ready-to-use applications to fully tailored solutions.
