Why Route and Flow Optimization Matters
The routes goods follow through a supply chain network determine transport cost, lead time, carbon emissions, and service reliability as directly as any other structural decision. In a complex network with multiple production sites, distribution tiers, and customer delivery points, goods can reach their destination through many different combinations of facilities, lanes, modes, and intermediary stops. Some of those paths are significantly more efficient than others in terms of total cost and service performance. Route and flow optimization is the discipline of finding the paths that perform best across the network as a whole rather than optimizing individual lanes or shipments in isolation.
This operates at two levels. At the strategic level it addresses which lanes and flow paths should connect facilities in the network, how volumes should be distributed across alternative routes, and how the transport network should be structured to minimize total cost while meeting service requirements. At the operational level it addresses how vehicles should be routed to serve delivery points efficiently given capacity, time window, and sequencing constraints. Both levels matter and both benefit from optimization, but they require different analytical approaches and operate on different planning horizons.
Why Route and Flow Optimization Is Challenging
At the strategic level the difficulty is that flow paths interact across the full network in ways that make local optimization unreliable. A routing decision that minimizes cost on one lane may increase cost or reduce service on another by changing the volume flowing through shared consolidation points or intermediate facilities. The total cost of a routing configuration depends on how all flows interact across the network simultaneously, which cannot be evaluated reliably by optimizing each lane or flow path independently.
At the operational level the difficulty is combinatorial: the number of possible vehicle routes that could serve a set of delivery points grows exponentially with the number of stops, making manual route planning increasingly suboptimal as network complexity increases. Service time windows, vehicle capacity constraints, driver availability, and delivery sequencing requirements all add constraints that further limit the feasible solution space and make optimization essential rather than optional.
The Cost of Suboptimal Routing
Routing inefficiency accumulates quietly across every shipment that follows a suboptimal path. Unnecessary distance adds transport cost and carbon on every cycle. Poorly consolidated flows underutilize vehicle capacity, increasing cost per unit delivered. Routes that do not respect time windows create service failures. And flow paths that were set historically and never revisited may no longer reflect the most efficient structure given how the network has evolved. The cumulative cost of these inefficiencies across a large distribution network is significant and largely addressable through systematic optimization.
Why Traditional Approaches Fall Short
Strategic routing decisions in most organizations are embedded in the network design and carrier contracting process and are rarely revisited between major network reviews. Operational routing is managed through a combination of planner experience, fixed route templates, and basic routing tools that optimize individual routes without considering the full vehicle fleet and delivery schedule simultaneously. Neither approach produces consistently optimal outcomes because both treat routing decisions as local problems when their consequences are network-wide.
What Effective Route and Flow Optimization Requires
Supply chain leaders need analytical capability at both levels. At the strategic level they need a network model that evaluates alternative flow paths and routing structures across the full supply chain simultaneously, optimizing against total cost, service, carbon, and capacity constraints. At the operational level they need optimization that considers all vehicles, all delivery points, and all constraints simultaneously to find the routing plan that minimizes total fleet cost while meeting service windows across the full delivery schedule.
A Practical Approach to Route Optimization
  1. Map the current routing structure and its cost and service performance. At the strategic level, document which lanes and flow paths currently carry which volumes, at what cost, and with what service outcome. At the operational level, document current vehicle utilization, route lengths, service window compliance, and delivery cost per stop. This baseline reveals where routing inefficiency is most concentrated.
  2. Identify the alternative routing structures and flow paths worth evaluating. At the strategic level, generate candidate routing configurations that represent genuinely different structural approaches: direct flows versus hub-and-spoke consolidation, alternative intermediary facilities, or different distributions of volume across parallel lanes. At the operational level, define the constraints that govern feasible vehicle routes: time windows, vehicle capacities, driver hours, and delivery sequencing requirements.
  3. Optimize routing decisions at network level, not lane by lane. At the strategic level, evaluate alternative flow configurations across the full network simultaneously, finding the routing structure that minimizes total transport cost while meeting service and capacity constraints. At the operational level, optimize the full vehicle schedule simultaneously rather than building routes one vehicle at a time, which consistently finds lower-cost solutions by identifying consolidation opportunities that sequential route building misses.
  4. Build a refresh process for both strategic and operational routing. Strategic routing should be reviewed when the network changes materially: when facilities open or close, when volume patterns shift, or when carrier rates change significantly. Operational routing should be re-optimized regularly as delivery schedules, customer locations, and vehicle availability evolve.
What Strong Route and Flow Optimization Looks Like
A well-optimized routing structure moves goods through the network via the paths that minimize total cost and carbon while meeting service requirements, with vehicle capacity well utilized and delivery schedules built around real constraints rather than historical templates. The routing logic is transparent and repeatable rather than embedded in individual planner knowledge, which means it can be updated systematically when conditions change.
Common Pitfalls to Avoid
  • Optimizing individual lanes or routes without considering network interactions. The most efficient route on a given lane is not always the most efficient choice for the network as a whole.
  • Using historical route templates without regular re-optimization. Delivery patterns, customer locations, and vehicle availability change continuously, and routes built for yesterday’s network are rarely optimal for today’s.
  • Separating strategic and operational routing decisions. The strategic routing structure determines the context within which operational routes are built, and inconsistency between the two levels creates inefficiency at both.
How AIMMS Supports Route and Flow Optimization
AIMMS supports route and flow optimization at both strategic and operational levels. At the strategic level, AIMMS evaluates alternative flow paths and routing structures across the full supply chain network, finding configurations that minimize total cost while meeting service, capacity, and carbon requirements simultaneously. At the operational level, AIMMS applies advanced optimization techniques to vehicle routing problems, finding solutions that account for time windows, vehicle capacities, and delivery sequencing constraints across the full fleet and delivery schedule simultaneously rather than building routes one vehicle at a time. For organizations with complex multi-tier distribution networks, specific vehicle routing constraints, or routing optimization needs that span both strategic network design and operational scheduling, AIMMS supports fully tailored solutions on the same optimization foundation.
“The most efficient route between two points in a network is not always the shortest one. It is the one that performs best when every other vehicle in the fleet is also trying to serve its deliveries at the same time.”
The Outcome
Organizations that optimize routing at both the strategic and operational level operate with lower total transport cost, better vehicle utilization, more consistent service performance, and lower carbon emissions per unit delivered than those that manage routing through fixed templates and local optimization. The improvement compounds across every delivery cycle, making it one of the highest-frequency sources of value in transportation management.
Speak with AIMMS to explore how transport routes and flows can be optimized across your network, from ready-to-use applications to fully tailored solutions.
